Latest post 12-09-2009 4:27 PM by Dillen. 4 replies.
Page 1 of 1 (5 items)
  • 12-09-2009 2:16 PM
    cdx 000?
      hi everyone, purchased a cdx player which arrived by post today,removed transit screws and it also even had the card in the cd which i removed, i then left it to warm up for 2hrs,when i connected it all up everything works but when pressing play disc wont spin,and ? mark appears in digital display, i dont really want to send it back if it is an easy fix but as i am not electronically minded i may have no choice,the condition of it is simply outstounding so i am dissapointed it wont play .......help!Sad
  • 12-09-2009 2:39 PM In reply to
    Re: cdx 000?
    Glen
    The ? appears when the deck can't register that a disc is present in the player. Sometimes this can happen when loading the CD if it slips down a little off the platter, then when the lid closes the spindle doesn't line up with the hole in the centre of the CD. Have a check to make sure the CD is sited properly on that platter!
  • 12-09-2009 3:07 PM In reply to
    Re: cdx 000?
    hi john, have checked and rechecked but to no avail any other ideas? thanks so much for your help glen.
  • 12-09-2009 3:24 PM In reply to
    Re: cdx 000?
    In that case then it's likely to be an electronic issue and I'm not very electronically minded! Someone else may be able to help you though!
  • 12-09-2009 4:27 PM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: cdx 000?
    Typical for a Beogram CD X, especially after moving/transporting it.
    Cracked solder joints in the power supply and/or those dreadful rivet vias
    on the servo board.
    Repairs to this machine are generally a bit time consuming but usually
    not impossible and expensive parts are rarely needed.
    A bit goofy if you haven't done CD X's before.
