Hi Beoworld members,
Does anybody can tell me where the RDS module or pcb is located in an Ouverture or better how it looks like (picture).
Have to explain somebody from a distance to check wether he has an RDS module in the Ouverture. This defect Ouverture has already been opened, so from a picture he could surely tell me if it's there.
Maybe this link http://link.marktplaats.nl/301817427 would help!
Thanks guys!
B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
Beovirus? What's that?
It's located on the radio board, a silver box ca. 8x8cm.
The rear mainboard must be opened to see it.
But it can be mistaken with the masterlink cpu module, it's the same size. This is on the right side under the big cd controller.
Danke, so this pcb can not be seen on the picture (rear view)?
No, it's invisible in the middle of the 2500/overture.
Seller was so kind to send me two pictures. Can you recognize, Die Bogener, if he's got the right location.
Thank again for your support! Much appreciated..
This is the CPU module.
The RDS module would be on the other side...
Unfortanetely no RDS found.
Danke schon Die Bogener for your support. Much appreciated!
Leslie
