Hi Kjeld
That is absolutly correct.
You only need a CA-module and a card from your provider... (If you are from Denmark and have Yousee cable, you will not even need a card og a CA-module from sep 9.)
I use the DVB-HD module with Stofa and things are working ok. There will be an DBV-HD software update shortly that should take care of small issues.
Be aware that the CA-module requires a HDMI input in the tv.
									    BV7-40 MK IV, BL5´s, BL3´s, BL 3500, BL7-4, BS3000, BC 6-23, BV 1, BS3.
