Latest post 11-28-2009 2:03 PM by wink. 3 replies.
Page 1 of 1 (4 items)
  • 12-03-2007 6:35 PM
    • wink
    • Not Ranked
    • Joined on 12-03-2007
    • Posts 4
    • Silver Member
    Beovision 3 and PVR
    Will my Beovision 3 with stb module control a Humax 9200 PVR?  There is an earlier model Humax box listed in the menu, but I don't know if the codes will be the same?
  • 12-04-2007 6:11 AM In reply to
    Re: Beovision 3 and PVR
    Unfortunately that Humax box is not on the current STB list.
  • 12-04-2007 7:14 AM In reply to
    Whilst the 9200 is not currently in the STB controller list you may wish to try it with earlier box settings for two reasons:-
    1. Manufacturers tend to use the same codes from model to model just adding new codes where required
    2. Often the core everyday functionality remains the same from one model to the next
    Regards Keith....
  • 11-28-2009 2:03 PM In reply to
    • wink
    • Not Ranked
    • Posts 4
    • Silver Member
    Update - no, the STB would not control the Humax, but I successfully achieved this with a Lintronic box.
