Just wondering using a din to RCA?
Thank you, Stvee
You will need a RIAA pre-amplifier to go between the RX2 and the 2300
Once that is sorted you can determine which adapters are required.
Regards Graham
True if you have a Beocenter 2300 (with Powerlink out).
The 'old' Beosystem 2300 (consisting of BM2300 model 2905 and BC2000/BG2000 and the like) has phono input, but this is a rare model, being the predecessor of the BM2000 model 2911/2913/2917.
