Latest post 11-13-2009 7:07 PM by Master_Geek. 4 replies.
Page 1 of 1 (5 items)
  • 11-13-2009 10:06 AM
    Beocord VX7000 - remote ?
    Hey. Can anyone please tell if a Beolink 1000 remote will work with a Beocord VX7000 videotape recorder? It is listed to work with Beolink Beo4 and 5000, but can the Beolink 1000 also control it?
  • 11-13-2009 10:08 AM In reply to
    Re: Beocord VX7000 - remote ?
    Yes - there is a place in the menu where you can change between the Beo4 and the Beolink 1000 I seem to remember. Of course it is the TV that is really being used.
  • 11-13-2009 10:12 AM In reply to
    Thanks for the quick answer. Is it in the menu of the VCR og the TV? What do you mean with "it is the TV that is really being used".
  • 11-13-2009 2:33 PM In reply to
    The VX7000 has no IR eye. It is controlled via a Beovision with the remote signals being picked up by the TV and sent along the SCART cable. No Beovision, no remote control.
    To change which remote works, first you need to make sure you have the correct VX7000! Early ones have a type number starting 45, later ones start 46. Only later ones work with the Beo4. I attach the instructions on how to switch remote types.
  • 11-13-2009 7:07 PM In reply to
    Thank you! That was all the help I needed!
