1st March February 2012
Latest post 01-21-2010 6:12 AM by beaker. 78 replies.
12-22-2009 10:41 AM
sebastian
- Joined on 12-22-2009
- France
- Posts 38
Beomaster 900K & a novice needing help
Hi there everybody,
this is one of those "just registered and the first post is a help request" situations. Sorry for that. But i'm no complete stranger to this forum, and as a lurker have searched and read everything i can find during a last week or so, but without result. I'm no *real* amateur of B&O, nor a collector, just someone appreciating the craftmanship and beauty of their work. I'm rather a vintage design buff. These things are just a thing of beauty to look at, just as a Polaroid sx-70 (just one example) is a thing of beauty to look at. I've especially always had a soft spot for the Beomaster 900 & 1000 variations, and wanted to get me one one day, but as it was not an obsession, time went by. Then recently i had the opportunity to get one 900K for the cheap, and so... i got it.
And here's why i'm here.
It doesn't work. I'm no technician, but am handy. I've already repaired and built stuff, as long as it's mechanics, but am at loss with electronics when no direct instructions are given, and here it's clearly *way* over me. I've downloaded and studied all the service manuals and schematics from the web but am just illiterate with electronics. I called the local B&O shop, but to my disappointment their prices already *begin* at a bit expensive, without any idea as to how high it might end up with. And this without knowing if it's going to be a complete overhaul or just one capacitor. And so i wanted to ask you specialists, if there might be something symptomatic with these models that i could try as a first aid before writing it off as definitely needing *professional* help. You know, testing this, measuring that, with those few components that are the most often the cause of failure in these models ?
Should you accept, i'll describe the patient a little to begin :
so it's a 900K with the dark grey grille in front. On the serial number sticker at the back, it's marked "S 290 BEOMASTER 900 K 919369". It is a model with the stereo decoder installed. It also has - and i don't know if it has any meaning, but i've seen different models so here goes - the voltage range of "150, 220, 130, 250, 110, 240". The exterior is in quite nice condition, nothing indicating bigger shocks. The knobs are all the heavy metal ones. Didn't come with any documents, outside or inside. That's for the model identification.
Symptoms :
does nothing. When i plug it, nothing happens. No sound what-so-ever. When opened, nothing seems broken or burnt to the eye. Nothing gets hot with time when plugged to the wall. All the lamps (well, all three of them that i've found) are burnt. I've tried with one replacement lamp and it doesn't light. The three fuses (is that all ?) seem all right, even though they were a bit covered in dirt (cleaned since).
And that's that. I've no idea as to what to try next. So if any of this inspires any of you, i'd be grateful for any advice, or be more than happy to measure or test any suggestions that you might have. I have a simple multimeter for testing. I can take photos if needed, but can't do extreme close-ups for a few days since i've not my camera with me (will be with an iPhone in the time being).
So there, thank you so much in advance for *any* assistance you might be able to provide, i'll sure appreciate all the attempts.
Sebastian.
Dillen
- Joined on 02-14-2007
- Copenhagen / Denmark
- Posts 5,008
Re: Beomaster 900K & a novice needing help
Welcome to Beoworld !
What a nice radio ! The first thing would be to check if there is any voltage anywhere. I suggest measuring AC voltage on the rectifier primary first. Then DC on the secondary side. Let us know the results.
The dial lamps are good indicators for voltage and transformer function so I suggest you make sure two good ones of correct wattage are mounted. The stereo indicator lamp is not important right now but will also need to be of correct wattage when a new is fitted (different from the dial lamps).
tournedos
- Joined on 12-08-2007
- Finland
- Posts 5,808
Welcome from me as well, and congratulations! A 900K was my first B&O piece as well
I'd add that you need to either measure the fuses or replace them with new ones - those glass tube fuses can be blown (or corroded) even if they seem OK. Sometimes the wire breaks when you remove them and the end cap gets twisted a little.
You have a rather early example there as the type designation is still S290. It got the normal four digit type designations in a year or two after introduction I think.
Hope it will be a simple fix!
sebastian
- France
- Posts 38
thanks so much for your quick replies, and your warm welcome.
I started by measuring the fuses, and what do you know, i should've certainly done it even before posting here ; the second mains fuse (the 0,25A one with a little "springy" wire), even though perfect visually, is dead. The other two are fine. So i'm off to try and find a new one right away. I'll try and source the correct lamps at the same time (if i get it right, that's two 6,3V for dial, and one of minimum 19V for stereo).
Will report ASAP.
Thanks again.
Sebastian.
sebastian
- France
- Posts 38
Ok, so with a new fuse in place, when plugged to electricity, the SP1446 regulator transistor at the back gets extremely hot within seconds. I disconnected the unit immediately. Now what does this say ?
[EDIT] In the meantime, i looked a little closer, and the red wire leaving from the SP1446 has melting marks (seen how it gets hot, no surprise) [EDIT]
Sebastian.
Dillen
- Posts 5,008
Most likely a short somewhere. Let's have an ohm reading (unpowered of course) across capacitor 514. It's a 64uF electrolytic capacitor sitting at the rear center of the amplifier board, providing a good and easy place to check amplifier voltage, easy to measure across from the solder side.
sebastian
- France
- Posts 38
Dillen: Let's have an ohm reading (unpowered of course) across capacitor 514.
On the scale of 200, i get a reading of 00.3 (which means to me it's not shorted, right ?)
[EDIT] In fact no, it's exactly the contrary, i believe. It should go up progressively if it was working, right ? Told you i was useless in electronics. [EDIT]
I also had the time to mess around in my distress, and desoldered the SP1446 with its resistor to measure them, for what it's worth :
- the resistor = 13 ohm (i couldn't find it's supposed value in the schematics, what should it be ?)
- SP1446 (scale 200k) : C-E = 00.5 / C-B = 00.7 (no idea if i did that right ?)
Sebastian
Dillen
- Posts 5,008
OK, now desolder one pin of capacitor 514, lift it out of the board and measure again, this time we need two readings; On the board tracks and directly across the capacitor.
sebastian
- France
- Posts 38
Ok, i desoldered the minus (-) leg.
Across the capacitor = slowly raises to infinity (so now it means it was ok then).
I'm not sure what you mean by "on the board tracks", but if it means the solder joint of the leg that is still soldered (+) on the underside of the board, and directly the desoldered leg, then that's the same (raises to infinity), or if you mean the solder joint of the soldered (+) leg and the now desoldered empty (-) point on the board, well, it gives zero.
I'll be making a go at the local electronics store today to get the lamps, is there anything i could get that could be suspect and would be better off changed anyway ?
Thanks for your patience, i'm not really making this any easier now am i...
Sebastian
Dillen
- Posts 5,008
OK, you can solder back the capacitor 514 now. It seems to be OK.
The output stage transistors could be worth checking too but I doubt the fault to be here because the resistance is so close to zero ohms. I would expect to see the emitter resistors reflected as the minimum ohmic value if an output stage is shorted.
You can desolder one side of the large power supply filter capacitor and measure across it like you did capacitor 514.
sebastian
- France
- Posts 38
Dillen: You can desolder one side of the large power supply filter capacitor and measure across it like you did capacitor 514.
That's the enormous blue one (1000uF), right ? Same thing, raises slower but goes on forever and seems fine.
Sebastian
Dillen
- Posts 5,008
Yes, that's the one. Does it read a steady zero ohm across the cap when mounted ? Also check the output stage transistors, all four across collector/emitter and across the two output caps (800uf) at the rear panel.
sebastian
- France
- Posts 38
Dillen: Does it read a steady zero ohm across the cap when mounted ?
Well, at the scale of 2000k it's a steady zero, and at 2000 it's 364 steady. Am i right by understanding that the caps should be tested with the highest value available on the meter (mine is 2000k) ?
Dillen: Also check the output stage transistors, all four across collector/emitter and
Ok, so i have no idea about the polarity of these suckers (on the SP1446 it was noted), so bear with me, there was something that didn't seem right ;
with the transistors desoldered, and the ohm meter on 2000, i first tested them all with the positive (red) on the Collector, and negative (black) on one of the legs. They all gave about the same result ; between 600-800 on the top leg, and infinity (1) on the bottom one. Then i tested with the negative on the Collector, and positive on the legs, and for all four it was around 1200 on the bottom leg and for three of them infinity (1) on the top one. The furthermost left one (that's next to the antenna socket) gave all the time about the same value for the two legs (i must've measured ten times to be sure). What's funny though is that i just tried again, and now it measures the same as the others (gives a figure, then jumps to 1) ? Significant ?
For the output caps, did you mean to test them alone, or the transistors with the caps ? I did test them alone, and they seem ok (value keeps growing). If you meant with transistors, i'm not really sure how to go about that.
Thanks so much again for your time, don't hesitate to tell me when it's too much, i always get too carried away with projects (a bit stubborn i am).
Sebastian
Dillen
- Posts 5,008
You will always get the most precise reading at the lowest possible setting of the meter. Obviously a serious short somewhere and we will have to isolate some circuits to diagnose further. On the large blue capacitor, there's usually a bunch of leads going to one of its tags and only one or two going to the other. Try desoldering the large bunch from the one tag and measure from the other tag to each lead, one at a time to see which one(s) has the short.
Alternatively, if the exact ohmic reading was lower across cap 514 than across the big blue cap, desolder the two red leads that go to a solder pad near cap 514 (usually to the left of it if facing the front as you would normally do) and measure across 514 again. This will isolate the amplifier section.
sebastian
- France
- Posts 38
Ok, so just a couple of observations in the meantime ; the more i look at the innards of this thing (it's actually amazing how you can have a sense of doing something just by looking at something incomprehensible, i must have something wrong with me), the more i get the feeling that something fishy has been done to it. I just found in the wire-bunch that runs along the back wall, two naked leads that were wrapped in electrical tape together. They come from the right channel external speaker connector socket. They are the gray/white striped & the black wires that respectively go to the inside of the big pin and the center pin.
There has also been some not-so-pretty resoldering done on the socket that takes the integrated speakers plug. The wires look of origin, but the soldering definitely doesn't. I have a feeling that those loose wires should maybe go to the socket, the length is perfect. For now the five pins of the socket are, from left to right in half-circle by the bottom :
1. black/white wire
2. brown wire that connects with pin 4
3. free
4. brown wire that connects with pin 2
5. red/white wire
Now, what's this ? There was a problem and someone eliminated a channel ? I recall reading here something like this.
Also, another thing, what's the value of the top mains fuse ? It must've burned once i changed the bottom 250mA one because it was ok before, but the problem is there's absolutely no markings on mine for value, and i can't locate it on the schematics, for a replacement ?
[EDIT] Oops, Martin, you posted just before, didn't see it. Will try what you're suggesting now. [/EDIT]
Sebastian
Dillen
- Posts 5,008
Yes, and just added a bit to it as well.
You need to check those leads against the servicemanual and make sure they are properly insulated.
Dillen
- Posts 5,008
Note that the 5-pin DIN pins are not sequentially numbered. Taking that into consideration, the leads seems correctly mounted.
The two mains fuses are 250mA Slow-blow The dial lamp fuse is 1A Fast-blow
sebastian
- France
- Posts 38
Perfect, thanks for all the information. In fact, armed with my newly acquired intelligence, i remeasured the caps at the smallest scale (200), and the 514 measures still 00.3, and the big one is higher no matter which way i test it. So i desoldered the two red wires like you suggested (isolating the amplifier).
Sebastian
sebastian
- France
- Posts 38
Dillen: You need to check those leads against the servicemanual and make sure they are properly insulated.
Yes, sorry about the rambling, i'll try and refer to schematics so as to not invent my own conventions (thank heavens for your patience).
I've been checking and rechecking the wires with the schematics, and there's something that i just don't get ? In the image included i've indicated on red how the wires are right now (and this time i can confirm it). The output cap (800uF) is connected to the right speaker pin 4 (as it should), the pin 3 wire and one of the 2 grounds from pin 2 are the cut & loose ends that i found taped. It's instead the pin 2 (the ground, is it not ?) wire from the mono speaker that goes to the pin 1 of the internal speaker socket, and the pin 1 wire from mono to pin 4 of the left speaker (here also, as it should). Everything else is as it should. I won't even try to understand it, but surely it's not right ?
Sebastian
sebastian
- France
- Posts 38
Dillen: Obviously a serious short somewhere and we will have to isolate some circuits to diagnose further.
Done. Of the 7 wires, 5 3 2 indicate a solid 1 when measured. They are the 2 black ones that connect to the 2 resistors 512 (512a & 512) 547 & 643 on the same board as cap 514 (the amp board), the two black ones that connect to each PIN 2 of left & right external speaker sockets, and the black one that connects to the selenium rectifier (N° 233 in parts list in the manual, didn't find it on the schematics, the flat board-like thingy against the back wall next to transfo and the big cap).
Sebastian
[EDIT] Oh, and Merry Christmas everybody [/EDIT]
[EDIT 2] Correction on the resistor numbers [/EDIT]
[EDIT 3] After some insulation fixing (or so it would have seemed) on the output transistors, left with 3 problems [/EDIT]
[EDIT 4] Don't ask how, but i'm left with the 2 speaker PIN 2 wires shorted. I left them loose and lit up the 900K with a new lamp and nothing exploded nor burned. On the contrary, nothing got hot and the light worked. Now what's with these speaker wires ? [/EDIT 4]
[EDIT 5] Of course there's nothing with the speaker wires. Right ? [/EDIT]
sebastian
- France
- Posts 38
Ok, can you guess i'm spending this Christmas alone ?
Must've been all the desoldering and resoldering, and the fact that one of the output transistors had some faulty insulation (i don't know, could it ?), but gradually i put everything together, and at each step it seemed fine, until just a minute ago i tested it complete... and MUSIC !
Nothing gets hot, lamps work, even the low current that i felt in the beginning at the back when touching it is gone (a grounding issue ?). Ok, so it only plays on the left speaker for the moment, and there's an underlining hum static (kind of like inbetween stations) present on radio, tape and turntable presets when nothing's on and the volume is turned up, but hey, that's pretty much 200% better than when i got it. Also, i get only like 5 stations with the tuner (with stereo decoder & the internal antenna).
Now to try and see for the rest.
Sebastian
[EDIT] Ok, the hum is almost gone, another grounding issue. The two main concerns left are the missing right channel (?!) and the static "shhh" when volume is high, on all presets. [/EDIT]
[EDIT 2] So my guess is that initially there was a problem with the right channel, and whoever it was that has tinkered with the speaker wiring that was pointed out in a previous post, "solutioned" it by feeding the mono speaker (that is just a second left channel, right ?) to the right internal speaker (which works, proving that the speaker is ok). Now how do i find what's wrong with the right channel ? Is it on the amp board ? [/EDIT]
Dillen
- Posts 5,008
Wow, good job !
Swap the leads to the speakers to see if it's a speaker fault or listen carefully as you power on/off the Beomaster or switch channels for a thumb or any other sign of sound from the otherwise dead speaker. Check potentiometers, especially the balance potentiometer at the backside. It's often left unused for ages and will easily cause a dead-channel problem like this. Check also for wires broken off the main board, especially below the amplifier section, leads will sometimes break off when the amplifier section has been swung back and forth several times and may not be obvious.
The persistent static noise will most likely be one of the AC128/AC151 transistors in the output amplifier, typically the first or second nearest to the input. Again, if in doubt or lacking parts, swap a transistor with the matching one from the other channel.
sebastian
- France
- Posts 38
Dillen: Wow, good job !
Cheers, Martin, but this is entirely thanks to you. I wouldn't have even tried anything on it was it not for your patient instructions when it was clear (and still is) that i don't know anything on the subject.
Dillen: Swap the leads to the speakers to see if it's a speaker fault or listen carefully as
Yeah, well, so, i redid all the solders on all the speaker wires, and the right channel came back. So, ok, it's cool of course, but also a bit frustrating because all in this seems so... random. I mean, for all i know after all this, it was just a few bad solder joints and what-not.
I couldn't locate the balance pot, where is it exactly ?
Dillen: The persistent static noise will most likely be one of the AC128/AC151 transistors in the output amplifier, typically the first or second nearest to the input.
Erm, could it be that different models have different numbers ? Because i'm having only (per channel) two AC126 (the first and second from the outside, with letters "r" and "s" on top of them respectively), one AC153 (alone in the middle, nothing on top, on my schematics i have AC128 here), one AC127 (next to AC153, closest to middle of the board, with a "D" on top), and one AC132 (also with a "D" on top).
This said, now that both channels are working, the static is identical on both, would it still mean the transistors ? Also, it's practically inaudible unless the volume is very high (well higher than acceptable listening levels if there's music, but which doesn't mean i wouldn't mind getting rid of it). Also, there's a very quiet hum behind the static when the volume is at max.
Another thing (but here we're getting to fine-tuning) is that the sound is a bit "muddy", sure i love my vintage warmth but here it's a bit more than that. The bass has to be absolutely at zero level otherwise it gets dirty, and even then it's far from crispy (and of course, lacks punch/bass). I removed all the wall isolation stuff that was retrofitted in the cabinets, and that helped some, but it's not that. The speaker elements seem ok as well. I imagine that here we're getting to the audio signal level, and it's going to be all about old caps, or is there anything obvious to be tried before ? Speaking of caps, is there any kit available for this model ?
Aaand, do these models require an external antenna (like some long wire) to work well ? Cause i'm having some difficulties getting perfect reception ?
Wow, it still don't seem finished.
Sebastian
Dillen
- Posts 5,008
Different types of transistors can be used, AC126 is possible. I seem to remember that the first transistor is closest to the nearest outer corners of the amp. board. The service manual will tell you which one(s). It's possible that the same fault is present in both channels but of course, it could also be caused by something else. Is the static present also with the volume control set at zero ?
The rockwool is supposed to be in there and you shouldn't judge the sound with the chassis out of the cabinet. It's a pressure chamber system so depends greatly on a closed cabinet.
An internal FM antenna (and also an AM antenna) is provided. The FM antenna is in the form of two (usually black or red) leads in grooves at the inside of the wooden cabinet. They should have a plug to fit into the red socket at the back. If not, you will have to make something up to fit - or connect an external antenna. In most cases, the internal antenna will be more than adequate.
sebastian
- France
- Posts 38
Dillen: Different types of transistors can be used, AC126 is possible.
Yep, that's AC126 for me, will have a look at them.
Dillen: It's possible that the same fault is present in both channels but of course, it
No, absolutely not. In fact, it's impossible to hear at a reasonable volume. I'd say it's audible starting from the last quarter of the volume pot. And it's like soft-conversation-loud when the volume is at max. With a weak hum underneath for which i must press my ear against the speaker to be able to hear it. I may in all fairness have misnamed the symptom, it's maybe in reality more like a hiss with some grain. That's why i said it's sort of like between FM stations, or i could say the equivalent of snow on tv. The sort of stuff you'd hear on old tape between two songs when loud. I just say this because i suddenly started to imagine that maybe static for those who know their stuff is something else than it is for me, something very particular.
Dillen: An internal FM antenna (and also an AM antenna) is provided.
No i have the internal antenna and it makes all the difference in the world between plugged or not, it's just that i can't seem to find the sweet spot on the stations, it's always a little off. Or maybe that's just me stuck in the present with digital expectations, and not yet acclimated.
Sebastian
[EDIT] Oh, how would one go about it to change the mains cord & plug to a modern earthed/grounded one ? Would it be safe to connect the earth/ground to the same bolt where the earth of the big cap connects, behind the transfo ?[/EDIT]
