Latest post 11-17-2009 4:50 AM by tournedos. 7 replies.
Page 1 of 1 (8 items)
  • 11-16-2009 3:21 PM
    • John
    • Not Ranked
    • Joined on 09-20-2009
    • BRISTOL UK
    • Posts 62
    • Silver Member
    B&O Speakers.
    I am curious about separate B&O speakers. I have been collecting Radios for some time and  my collection off B&O equipment has up to now been self-contained units.  I have noticed  the brochure description for separate speakers usually describes them in the singular. It then gives a price but it is not clear whether it is for each speaker or for the pair as they are usually used in a stereo system. Not a very important question, but can someone put me out of my misery without my having to pester the agents? Actually buying one as a speaker for one of my ancient mono sets seems a bit extreme.
    Regards
    John
  • 11-16-2009 3:29 PM In reply to
    Re: B&O Speakers.
    They do sometimes get priced as single speakers - I think it is to make the cost less of a shock! The price list here on Beoworld quotes a price for a pair. I would not really suggest getting one for your mono sets though - a vintage speaker will be better. The new speakers are active so connecting would possibly be an issue and a vintage speaker is likely to be very efficient. Which radio were you thinking of using? Beovox 1000s would seem a reasonable choice for most of the radios.
  • 11-16-2009 3:33 PM In reply to
    Re: B&O Speakers.
    All the prices I have been quoted are for pairs, except for the BelLab 2 sub-woofer and the BeoVision central speakers in the 7.x speakers that provide superior voice reproduction.
    BeoLab3s and BeoLab 4s are even boxed as pairs - (like pairs of course!)
    However if you wanted a single speaker a dealer may be able to do something ....
    First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
  • 11-16-2009 4:39 PM In reply to
    • John
    • Not Ranked
    • BRISTOL UK
    • Posts 62
    • Silver Member
    Re: B&O Speakers.
    Thank you both for satisfying my curiosity. I take the point about modern active speakers with older mono sets. So far I have concentrated on the Beolits as it is easy to illustrate how they evolved. Using modern speakers with them would be inappropriate and in any caseI don't mind not having Hi Fi type of performance.
    My next interest is the separates systems over the period where stereo came into use, starting with Beomasters for instance. The basic units are not too difficult to come by but speakers are more scarce. This is why I thought of using modern speakers so that I could actually play them.
    Strangely I find the price quoted for pairs less alarming than if they were quoted singly. I suppose it is because I  view it as getting two speakers for the price, whereas if it was quoted singly I think I will have to find the same money again.
    Thanks again
    John
  • 11-17-2009 12:12 AM In reply to
    Re: B&O Speakers.
    Did you look at the BeoSound 1 ?
    http://www.beoworld.org/prod_details.asp?pid=946
    It is a speaker and a radio and a CD player and has an AUX input so that you could connect the older sets (or an MP3 player) .......
  • 11-17-2009 2:04 AM In reply to
    Re: B&O Speakers.
    John:
    Still I find the idea of using anything from the current offerings with vintage equipment rather silly. Not the least because of the active/passive problem which would render most of an old Beomaster unused, but the price of any current models will get you a truckload of good vintage speakers from eBay! Granted you can't just walk into a store and come back out with some speakers, but I simply cannot imagine having any problems if you're based in the UK. Seems full of B&O speakers to me... and you can of course use any speakers while you search for a better match.
    The pricing single/pair seems also somewhat regional. Some 20 years ago, speakers were always priced per unit in Finland, and I guess in Scandinavian countries as well. At least B&O does it in pairs over here nowadays as well.
    -mika
  • 11-17-2009 4:19 AM In reply to
    • John
    • Not Ranked
    • BRISTOL UK
    • Posts 62
    • Silver Member
    Re: B&O Speakers.
    Mika
    I agree about using old speakers, especially with regard to modern active ones. In fact I have a pair of Beovox  speakers that I acquired with an early Beomaster  at an auction. These suffice for operating my later acquisitions just to check they work but not quite adequate for a system that I wish to use for listening in a more regular basis. I have seen many speakers on Ebay but I have yet to decide between showing how the speakers developed or just having a single pair that can be used in a comfortable room to enjoy listening. A representative  collection of speakers could take up a lot of space and may end up as only a display stacked as in a shop or warehouse. Not quite the way to treat B&O.
    My thoughts about a modern speaker as an extra speaker for a mono system were just slightly more than idle speculation. The comments in reply to my query have put that out off consideration.
  • 11-17-2009 4:50 AM In reply to
    Re: B&O Speakers.
    I'm sure we all share the problem of how to display the collection (or even just how to store them...). If you want to have a number of speakers displayed both nicely and in a useful way, the problem will be even worse. I'd guesstimate that three pairs is about the maximum you can have in a single "normal" room, still positioned optimally.
    So one example would be to have a pair of wall mounted early panel speakers or bookshelf speakers for the real vintage stereo (excl. Beolab 5000), a pair of S45.2 on a shelf or on the floor for the mid-powered '70s, and a pair of larger floor speakers (MC120.2 or similar) that would work all the way until the last models that could drive passive speakers.
    You can of course do with one pair for all. I've never shared the idea that the tiniest amplifiers would have problems with large speakers. I just connected a pair of S80.2's to a Beomaster 900 and it had absolutely no problems filling the room with bass! There will be a limit to it of course, but that's just a question of volume.
    -mika
