Hi, I am a brand new member who needs some advice. I have a 9500 Centre which has been a fantasitic piece of kit driving 3 x extra speaker kits
The speakers are either CX 50 / 100 or Bose - all non powered. I have had no issues since purchase in 1990 ish. What value..!
However I have an issue with the CD player. I load a CD and it plays. It take longer to start playing than usual. After maybe 5 minutes or if I change track, the machine clicks then turns off into standby mode.If the 9500 is not used for a week the CD will play longer.
Is the machine on the way out and if so what should I replace it with that with drive the B&O link system in the house being in mind all of the speakers require an amp?
The glass sensor touch panel is also lose, the foam holding it in place has lost its grip.
Do I move on or is it worth repairing?
Any advice appreciated.
