Latest post 10-27-2009 2:36 PM by yachadm. 1 replies.
Page 1 of 1 (2 items)
  • 10-26-2009 7:16 PM
    BeoSound 2000/Century glass door will not close
    I have a BeoSound 2000, circa 1995. Just recently, the glass door has stopped closing automatically, unless I unplug it then plug it back in. It continues to open when I wave my hand in front. Closing is the issue. This has happened before, but it's always fixed itself by power-cycling. Any advice?
    Thanks,
    Ewen
    Filed under:
  • 10-27-2009 2:36 PM In reply to
    • yachadm
    • Top 100 Contributor
    • Joined on 06-24-2007
    • Jerusalem, Israel
    • Posts 687
    Re: BeoSound 2000/Century glass door will not close
    The indicator that you always fixed it by power cycling points 99.9% to a power control capacitor.
    Learn from the mistakes of others - you'll not live long enough to make them all yourself!
