Latest post 10-20-2009 8:36 AM by Medogsfat. 1 replies.
Page 1 of 1 (2 items)
  • 10-20-2009 6:06 AM
    Identify a bracket?
    Hi Guys,
    It's Gareth here (one of the Team @ LifeStyle-AV)
    We at LifeStyle have been working incredibly hard to upload all of our current stock to the website and have come across a set of brackets we can't seem to identify.
    It is believed they may be for the S-Series speaker but none of us are 100% sure and were hoping the fine people of Beoworld can help.
    Here is a picture of the Bracket in question.....
    Thanks All!!!!
  • 10-20-2009 8:36 AM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Re: Identify a bracket?
    Yep - that's exactly what they are and will also fit some M & MC models. I have a pair of MC120.2's mounted on these. Luckily you also have the pegs which screw into the back of the speakers.
    I can't tell which model speakers they fit though as I think the hole centres differ between some models. Quite a rare item too!
    EDIT - just checked my brackets and I'd say the ones you have are for the smaller in the range such as the S35/45 etc... as mine appear to be bigger - the pegs on mine also seem a bit longer. Just a guess though but if you can tell me the distance between the hole centres (between the left & right slotted holes as your picture sits) I should be able to confirm a bit more. The hole centres on mine are approx 180mm.
    Chris.
