Hello,
I spotted BG4004 on sale with a couple of problems. The deck doesn't start up always with first press on PLAY (or is it START), but claimed that second press will do it. The other problem is that the tonearm doesn't rise up from the record fast enough after the playing.
As these decks doesn't show up too often on sale here in finland and i have not dared to buy one from farther, i would like to know are these faults difficult and/or expensive to fix and is it worth the effort? The deck is for 200e.
Kind regards,
Olli
