Latest post 10-24-2009 12:49 PM by Friedmett. 3 replies.
Page 1 of 1 (4 items)
  • 10-23-2009 4:49 AM
    • zazouzt
    • Top 500 Contributor
    • Joined on 04-17-2007
    • near Strasbourg/France
    • Posts 123
    IR Code Converter
    Hi Beofans,
    I have a beomaster 5000 and recently got  an IR Code converter to use the beomaster with BL1000.
    But  it doesn't work.
    Should the Link eye have a little red light on when all is connected ?
    I tried to add a powersupply ( it's usually  not needed with the BM5000), but this changed nothing.
    I know this is old stuff, but perhaps can someone help
    Zazou
  • 10-23-2009 11:45 AM In reply to
    Re: IR Code Converter
    Did you download the IR code convertor manual from Beoworld?
    Have you set the blue switch corectly? You don't need the power supply for the 5000 so drop it.
    Are the Left and right speaker sockets on the cable where they should go?
  • 10-24-2009 8:35 AM In reply to
    • zazouzt
    • Posts 123
    Yes i have the manual
    Yes i have set the swith as it was mentioned in the manual
    and yes, the left and right speacker socket are where they should go
    thanks
    zazou
  • 10-24-2009 12:49 PM In reply to
    Well I got the same kit.
    I just need the IR mini plug cabel with a blue LED before I can test it.
    Trying it at this point for BM8000 gives nothing. No light in the Sensor either.
    I'm going to my B&O dealer soon to see if they can help me with that Ir cabel.
