Latest post 10-19-2009 3:37 PM by msinn. 1 replies.
Page 1 of 1 (2 items)
  • 10-19-2009 6:14 AM
    • kai
    • Top 500 Contributor
    • Joined on 11-16-2008
    • Posts 81
    Bvis 7-40 MK2 And MacMini
    Hi Guys
    Does anyone know of any problems, using the new macmini with Bvis7-40 Mk2, the TV has been upgraded with the new hd panel and the latest software. Customer already has a skyhd box fitted and is using the DVI socket, as far as I know I cant use the componet connection, as there is no connector available. The new 2009 macmini are digital only, can I still use the vga socket??
    Regards
    Kai
  • 10-19-2009 3:37 PM In reply to
    • msinn
    • Not Ranked
    • Joined on 12-11-2007
    • Germany
    • Posts 48
    • Gold Member
    Re: Bvis 7-40 MK2 And MacMini
    What gives you the impression that the actual Mac Mini is "digital only"?
    Take a look at Apple's specification:
    • NVIDIA GeForce 9400M graphics processor with 128MB or 256MB of DDR3 SDRAM shared with main memory3
    • Extended desktop and video mirroring: Simultaneously supports up to 1920 by 1200 pixels on a DVI or VGA display; up to 2560 by 1600 pixels on a dual-link DVI display using Mini DisplayPort to Dual-Link DVI Adapter (sold separately)
    • Mini-DVI port
    • DVI output using Mini-DVI to DVI Adapter (included)
    • VGA output using Mini-DVI to VGA Adapter (sold separately)
    • Mini DisplayPort output
    msinn
