Latest post 10-19-2009 10:51 AM by joeyboygolf. 1 replies.
Page 1 of 1 (2 items)
  • 10-19-2009 6:44 AM
    Replacement Parts for Beolab 8000
    I have a faulty Beolab 8000 speaker.  The Fuse F1 (4a 250v slow blow) on the transformer board is blown.  However, it is a type I haven't come across before - circular (shaped like old style metal cased transistor) with two legs that just plug into the fuse socket.  Can anyone advise me where i can get such a fuse.  Part number is 6600068.
    Regards
  • 10-19-2009 10:51 AM In reply to
    Re: Replacement Parts for Beolab 8000
    The fuses are available from you local B&O dealer.
    Quote the part number and he can order for you.
    Regards Graham
