Hi
I have my BM5 connected to my BV7 in the main room with HDMI and Composite (for link room).
When I turn on BM5 in my link room and afterwards in the main room, then the BV7 does not use HDMI but Composite (SCART) instead. The picture quality is then very poor on a BV7.
If the link room is not using BM5, then the main room use HDMI.
Do you know if this is an intended feature by B&O? Or what can I do?
Thanx.
There is something about B&O.....
