Latest post 10-10-2009 9:04 AM by vikinger. 1 replies.
Page 1 of 1 (2 items)
  • 10-10-2009 6:25 AM
    • mbee
    • Top 50 Contributor
    • Joined on 04-18-2007
    • Paris, France
    • Posts 1,133
    Stupid question
    Hi everyone,
    Stupid question of the day : how to switch on/off some settins of the service menu (BV8 40) : I want to try switching off film mode, its set on 001, but I can't change the setting neither with the Beo4 arrows nor with the keypad?
    Thanks!
  • 10-10-2009 9:04 AM In reply to
    Changing BV8 40 Service Menu Settings: (not a stupid question!)
    Hi mbee,
    Can't help directly, but can I suggest that if you edit the 'Subject' heading in your first post to summarise your problem you will be far more likely to get a response from someone with the answer?
    Graham
    I used to be indecisive, now I'm not so sure. [W C Fields]
