Latest post 10-06-2009 5:57 PM by cooldude. 5 replies.
Page 1 of 1 (6 items)
  • 10-06-2009 1:11 PM
    • davlei
    • Not Ranked
    • Joined on 10-06-2009
    • Posts 4
    Beolab 3 Speakers - Is there a way to lower the sound?
    I have my Beolab 3's connected directly to the Squeezebox Duet, the sound is awesome. However, on volume 1 its actually quite loud. Can anyone help is recommending a way to reduce the volume? I have tried using the Rothwell attenuators but they didn't work as they needed to connect to the speakers rather than the squeezebox and they don't have available the correct DIN connection for this. I really appreciate help on this as I'm on the verge of returning the speakers.
  • 10-06-2009 4:42 PM In reply to
    Re: Beolab 3 Speakers - Is there a way to lower the sound?
    Do you have the Beolab 3s set to LINE?
  • 10-06-2009 4:45 PM In reply to
    • davlei
    • Not Ranked
    • Posts 4
    Yes I do.
  • 10-06-2009 5:15 PM In reply to
    Sorry to be some time! Been reading the manuals for the Duet. I see no reason why this does not work. It produces variable line level which is what the BL3s run on and you should not need an attenuator as it does not have a power amplifier. What cables are you using?
  • 10-06-2009 5:25 PM In reply to
    • davlei
    • Not Ranked
    • Posts 4
    No problem.
    I'm using a 5 Metre DIN - RCA cable, cost me £50 a pair from B&O. My local B&O store have popped over to examine this and it appears to be that the Duet, although has great sound output, the volume levels from the squeezebox are not as gradual as Bang & Olufsen Audios systems. For example Bang & Olufsen Audio system will go: 1,2,3,4,5,6,7,8 and so on, where as it seemed that the squeezebox is more like 4,8,12,16. So volume 0 is 0, but Volume 1 is 4, do you see? This is my problem, volume 1 on some songs is actually quite high and is too high to listem as background sound.
  • 10-06-2009 5:57 PM In reply to
    davlei:
    No problem.
    A friend of mine had a similar problem when he wired up his basement den. He installed a simple line level controller to solve it.
    http://www.hometech.com/hts/products/audio/volume/index.html
