Latest post 09-22-2009 11:37 AM by joeyboygolf. 7 replies.
Page 1 of 1 (8 items)
  • 09-17-2009 2:34 AM
    • Noah
    • Top 500 Contributor
    • Joined on 12-16-2008
    • Switzerland
    • Posts 120
    • Silver Member
    How to disassamble the covering of the Beolab 4500??
    Hi everybody!!
    I need help concerning Beolab 4500 speakers. I would like to remove the panels(aluminium/ plexiglas) of the speakers. Does someone know here to to disassabmle these parts??
    I'd be glad for any help.
    PS: How much are these panels worth today in a used condition with scratches??
    Filed under:
  • 09-17-2009 3:29 PM In reply to
    Re: How to disassamble the covering of the Beolab 4500??
    The plexiglass will probably just pull off - it is held by doublesided tape which will probably have rotted!
  • 09-18-2009 2:28 AM In reply to
    • Evan
    • Top 25 Contributor
    • Joined on 12-15-2008
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    My double sided tape has rotted and I havent replaced it, no need, however was attempted by previous owner.
    Evan
  • 09-18-2009 3:12 AM In reply to
    • Noah
    • Switzerland
    • Posts 120
    • Silver Member
    Okay! Thank you for the advice. I will try to pull it off. Is it possible to damage the speakers by pulling to hard?
    What about the aluminium panels? Are these hold by tape too??
  • 09-18-2009 4:55 AM In reply to
    The plexiglass is just held by two-sided tape, that won't be very hard to detach.
    The alu. parts are non-removeable!
    Ernie
  • 09-18-2009 5:13 AM In reply to
    It is easier to transfer the electronics to the new cases rather than to try removing the aluminium square!
    The plexiglass will break if you drop it!
    The cases are left/right handed.
    Been there, done that!!
    Regards Graham
  • 09-22-2009 3:44 AM In reply to
    • Noah
    • Switzerland
    • Posts 120
    • Silver Member
    But has anybody an idea how to remove the aluminium parts without damaging them?
    Thanx anyway for the help!!
    Regards.
  • 09-22-2009 11:37 AM In reply to
    Believe me you can't!
    Regards Graham
