Hello,
I own and use B&O audio and video products for nearby 20 years and still like it a lot! I'd like to build now my first surround setup using my MX6000. For aesthetical reasons I want use the speakers built into the MX6000 as center speakers, despite they might not be best from the sound quality point of view.
Here is the equipment that I actually have installed in my living room:
- BS9000, connected via PL to a pair of BL8000
- MX6000, connected via a Beolink converter box to the BS9000
- A DVD1, connected to the MX6000 using a scart cable
In addition to this, I also own a BeolinkPassive kit, a BeolinkActive kit and a pair of BL4000. I'd like to setup a surround system using the following compnents:
- MX6000/DVD1
- A third party AV pre/pro, with the preamp outputs converted to PL driving Beolab's (should not be a problem, can use the pre/pro trigger output to turn on and off the PL)
- MX6000 speakers as center speaker
- Pair of BL8000 as front left/right speaker
- Pair of BL4000 as rear left/right, alternatively some passive speakers combined with BeolinkPassive
- No subwoofer for the beginning
Now, here is the tricky part that worries me. I have no idea how to drive the speaker of the MX6000 by the AV pre/pro. Ideally, I would like to use the PL connectors on the back of the MX6000 and use the MX6000 as a beolab, so to speak. However, I guess that the PL on the MX6000 work only as audio output but not as audio input. The MX6000 has further passive speaker connectors, intended to drive external 8Ohm speakers. Now, again, I don't know whether these connectors can accept an audio signal to drive the internal speakers, which I could deliver from the BeolinkPassive kit. Obviously I don't want to try these things based on trial and error and risk permanent damage.
Hi guys, please don't let me down with my problem! Thank you for any feedback.
