Latest post 09-20-2009 10:15 AM by Seanie_230. 3 replies.
Page 1 of 1 (4 items)
  • 09-07-2009 5:45 AM
    • Seanie_230
    • Top 75 Contributor
    • Joined on 04-20-2007
    • Milton Keynes, England
    • Posts 962
    • Gold Member
    BV7 Panasonic DMP-BD55 PUC Help
    Hello
    All
    I have the Panasonic BD60 workign with the PUC for the BD55 and it works nicely.
    A few things i have noticed.
    The player does not turn on when you press DVD, it will turn off if you select off at source change.
    When the TV goes to standby using the timer it also does not turn off the player, when you have off at source change selected.
    Am i missing something?
    Is there a dedicated PUC for the BD60?
    edit: After speaking to my dealer today it appears that the Panasonic Pucs have been replaced with one generic PUC in the PUC generator program.
    Beovision 7 MKIV (Blu Ray)
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Optoma HD65 Projector
    Lintronic TT455-RT-238
    Beovision 3 MKII
  • 09-07-2009 1:09 PM In reply to
    Re: BV7 Panasonic DMP-BD55 PUC Help
    Hi Seanie,
    I use the BD55 PUC for my BD35 player. All works fine.
    The way how the DVD shuts down is selectable at the CONNECTION part of the OPTION menu.
    if you have the BD60 connected to the AV1, select AV1 and follow the menu.
    After you have Chosen these connection settings, you better first use the BD60 remote once/twice for switching on. This has somthing to do with the setting of the PUC program. Hereafter the BD60 should work properly.
  • 09-07-2009 1:15 PM In reply to
    • Seanie_230
    • Posts 962
    • Gold Member
    Hi again
    if i press dvd then go twice the player comes on and go 0 turns it off but i thought it was supopsed to be automatic.
    it does work if i select off at source change but not at TV standby shame.
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Beovision 3 MKII
  • 09-20-2009 10:15 AM In reply to
    • Seanie_230
    • Posts 962
    • Gold Member
    Hi
    I have been using the BD60 for a while now with the PUC called BD55 but B&O have now removed these from teh PUC table and the most recent it G Panasonic.
    This works just as well apart from the display is missing so you can see how far the film you have left.
    also
    Does anyone else notice that this player does not seem to remember last position viewed within a film?
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Beovision 3 MKII
