Hi everyone,
I was wondering if anyone has found a good infrared remote control extender that will work with Beolink 1000 and Beo4 to allow the remotes to be used in a different room from the main system? All the ones I've tried so far are fine for "normal" remotes, but they just ignore B&O remotes!
Thanks,
Steve.
Sounds Heavenly Cables are proud to be a sponsor of the BeoWorld Forum!
