Latest post 09-22-2009 3:36 PM by Large48. 5 replies.
Page 1 of 1 (6 items)
  • 09-14-2009 6:41 AM
    • JP999
    • Not Ranked
    • Joined on 09-14-2009
    • Posts 2
    Beovision Avant - Using scart sockets
    Dear all,
    I have a Beovision Avant 28 and want to connect three external units to it (Satellite receiver/Playstation and Wii). I have connected the Wii and the Playstation using the scart sockets at the rear and the satellite through the connectors for the camcorder.
    When i turn on the TV it automatically picks up that i have connected something in the camcorder sockets so the satellite comes on. I can access one of the scart sockets using the DVD button on the remote but there does not seem to be a way to access the other scart socket without going into the menu and using the setup options to change which scart socket is for the DVD. I hope you're still with me!
    My questions are, like on other TVs, is there a button that can toggle through the different inputs on the TV?
    Also, how do i access the 'camcorder setting' so i can watch the satellite without having to turn the TV off and on again?
    Thanks for your help,
    James
  • 09-14-2009 7:02 AM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    Re: Beovision Avant - Using scart sockets
    Hi and welcome to Beoworld.
    "My questions are, like on other TVs, is there a button that can toggle through the different inputs on the TV?"
    No, not necessary. If you have assigned your sources for example V.AUX for Wii, DVD for the Playstation and CAMCORDER for the stb you just press DVD or V.AUX and the Avant will be powered up, turns to the desired position and switches to the chosen AV port. I assume you are using a Beo4.
    V.AUX and CAMCORDER are hidden buttos in the LIST. If you do not find them, just add them. The manual describes how to do that.
    "Also, how do i access the 'camcorder setting' so i can watch the satellite without having to turn the TV off and on again?"
    Should work as said above, just press LIST until CAMCORDER and then press GO.
    Hope this helps.
    Stefan
  • 09-22-2009 2:50 AM In reply to
    • JP999
    • Not Ranked
    • Posts 2
    Hi Stefan,
    Thanks for the reply. How do i assign the sources and how do i find the hidden buttons? Unfortunately i do not have a manual.
    I have tried scrolling through the list but it only comes up with Camcorder as you suggested in your second answer.
    James
  • 09-22-2009 12:49 PM In reply to
    Become a Silver or Gold member and then all the manuals are available for download.
    Train Hard - Run Fast - Hit to Kill!!!
  • 09-22-2009 2:18 PM In reply to
    For modern equipment, you can find some manuals on the official site. Not as many as we have though and not the service manuals either!
  • 09-22-2009 3:36 PM In reply to
    Hey, I tried. ;-)
