Hello,
I am now in possession of a nice Beogram 8000, no scratches, nice lid. I got it cheap because I wanted parts for my 6006, especially the damn leaf spring for the lid.
The seller told me the PSU was busted. It was not: the connector had just found its way inside the block (no contacts then!), and in fact the deck works! I had to replace the tachodisc though, but I had a spare one, so no problem here. A couple of bad solder joints too.
The arm was a mess as always, but I managed to get it work fine. There was an MMC20CL attached, but alas no cantilever!
The problem now is the relay is not synchronised to the lift mechanism. I can hear the sound before the relay clicks, with the arm lowering down at the correct speed. Also, when I pause, the same thing happens, the relay clicks too late.
Otherwise it sounds just great, better than my 6006, heavens knows why, with the same cartridge and cable!
