I have a Beo4 with the AV button in the middle. (I believe that makes it an early version.)
I want to change the order of the soft buttons accessible from the LIST button but I can find no MOVE option. When I press Standby and LIST together the commands I can access by repeatedly pressing LIST are CONFIG?, ADD?, REMOVE? and OPTION? but no MOVE? Is my Beo4 faulty, or did the early Beo4s not have a MOVE? facility, or is it somewhere else in the menus?
I'd appreciate help. Thanks.
Regards,
Peter
