Fabric stuck using contact adhesive before it has dried so that tension of the fabric can be maintained - system worked well over the 1.20m length on the side!
Stand for Ouverture unfortunately doesn't move - the unit sits alongside an MX7000 tv under an open plan staircase - the disparity in heights of the bottom edge of the tv and Ouverture irked me so Nobby kindly supplied a knackered turntable unit which which was stabilised with some contact adhesive on the turntable ball ring
http://i74.photobucket.com/albums/i252/stotty1111/IMG_0875.jpg
think the above makes sense!
t
I always try to operate using/following the KISS principle -- Keep it simple stupid!
