Latest post 08-27-2009 11:01 AM by Dillen. 5 replies.
Page 1 of 1 (6 items)
  • 07-30-2009 9:15 PM
    Beocord 1200
    I recently purchased a beocord 1200 reel to reel on ebay, when I plugged it in it made a loud clicking noise. I removed the back panel and found the dive belt was broken as well as the much smaller, I believe it to be the, tape counter belt. Can anyone tell me where I might find replacement belts for this machine. Any help would be appreciated.
    John
  • 07-30-2009 10:27 PM In reply to
    • Evan
    • Top 25 Contributor
    • Joined on 12-15-2008
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Re: Beocord 1200
    I would either start with a dealer or the free tech support line Beocare, they might be able to help. Good luck.
    Evan
  • 07-31-2009 12:18 AM In reply to
    Re: Beocord 1200
    Try Dillen in here - he's got a lot of parts for classic equipment. The person at B&O Beocare wouldn't know where to begin ...
    Just search for Dillen here on the forum. He's got several posts in the Vintage section.
  • 07-31-2009 1:44 AM In reply to
    Re: Beocord 1200
    O rings can be cut to size and glued if you need new belts of an odd size. A Motor factor can supply them.
  • 07-31-2009 2:21 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Beocord 1200
    A belt set for this machine is currently in the making.
    It has been underway for a long time but hopefully ready soon.
    As Peter suggests, you can make a temporary solution by glueing ends of cut belts
    together but especially the capstan belt is not that easily accessed so not a very
    easy job at all.
  • 08-27-2009 11:01 AM In reply to
    • Dillen
    • Posts 5,008
    Re: Beocord 1200
    Drivebelts are now available for Beocord 1200 and 1600 open reel tapedecks.
