Try this....set the volume where you want it
then List until get to speaker, use left and right on Beo 4 to adjust balance
then
List on Beo 4 until get to A.Setup     might have to add this function to the Beo 4, once there press go
List will then bring up bass treble and loudness which can be adjusted and finally a store function.
Beosound 1, 5, 2000, and 3000
Beotime, Beotalk, Beocoms
