Latest post 08-26-2009 4:24 PM by gizmo69de. 2 replies.
Page 1 of 1 (3 items)
  • 08-25-2009 2:05 PM
    Reset possible ?
    Dear all,
    is there a possibility to reset the Beo5.
    I have managed to programm a permanent auto repeating function ( yes yes i know.... try and error...this time an error ;-)) )
    The beo is not reacting at all ...... and continues to send the function.... is there any possibility to make a reset or will i have to wait
    until power down of the unit ??
    Any help appreciated.
    cheers
    André
  • 08-26-2009 4:12 PM In reply to
    Re: Reset possible ?
    Andre,
    I am guessing that you have created a 3rd party XML file with either an inccorrect RAW code or using a repeat function.
    This problem is quite common since the recent software and firmware updates.
    The way to resolve the problem is to hold the centre button pressed for a very long time until the units turns off, then put it on charge for a couple of hours, then reconnect the Beo5 and download a configuration which does NOT contain your 3rd party XML configuration.
    Your Beo5 will be back working, but you will need to determine what has caused the problem and correct it before doing another download with the 3rd party XML file.
    Regards Keith....
  • 08-26-2009 4:24 PM In reply to
    Thx Keith,
    thats good to know... my Beo5 recoverd over night by using all the power for my repeat desaster... after reloading the batteries everything was fine again and i was able to download a version without my self made bug ;-)
    Next time i will continue to press the button... i´ve tried some of them yesterday evening.... even the center one...but not long enough...
    Cheers
    André
