Latest post 08-20-2009 4:26 AM by PhilLondon. 1 replies.
Page 1 of 1 (2 items)
  • 08-20-2009 2:01 AM
    LC1 BEO4 More Questions???
    Is it possible to set the light intensity to a predetermined level so that it always turns on to that setting via the BEO4??.  If so how does this work programming wise via the Beo4 remote???
    Am I able to hit one button on the BEO4 and have more then one LC1 in the room all turn on at the same time???
    Is it possible and acceptable to have more then one light connected to the LC1 if they both have a wattage rating half of what the LC1 is???
    THANX
  • 08-20-2009 4:26 AM In reply to
    Re: LC1 BEO4 More Questions???
    Striker,
    I would be wise you get the manual for these LC1. They can do all the things you mention and even more...
    You can download the LC1 manual, from Beoworld,  if you become a paying member of this site.
    You can get a LC2 user guide free from the Bang & Olufsen web site here:
    http://www.bang-olufsen.com/user-guides?cat=BeoLink&prodid=106&typeid=1
    They work in almost the same way.
    The LC2 guide is actually more useful as it shows how to use them from a Beo4. The LC1 guide probably only mentions the Beolink 1000.
    And Yes, you can have multiple lamps on the same LC1.
    If you have more than one LC1 or LC2 in the same room, you can program up to 9 light pictures, or moods.
    p.
