A white Beogram 8000 is quite rare, wonderful piece !
The fact that it's white (presuming it's original, it looks to be) could increase its value.
The tachodisc sits around the platter spindle, about halfway down the height of it.
Just not visible in the photo, the black subplatter covers what would have been the lit side of it,
the rest is in the flash shadow.
The tachodisc travels through an opto sensor (seen as two tiny square plastic
blocks, one above the tachodisc and one below) with wires attached.
It's safe to say that all photographic tachodiscs are dead by now.
The printed pattern falls off or dislocates, causing audible wow and/or a humming sound from the
deck for every revolution of the platter as the electronics struggle to get the speed right.
In severe cases, the display will flash some of its digits, indicating that the readout cannot be trusted or
the Beogram refuses to function altogether.
The tolerances of this disc is ridiculously tight.
No xerox machine, copier, scanner or printer will get it right (all has been tried), it's just not exact enough.
Replacing with a metal disc is the only solution (available from me as a repro part).
Note that the black subplatter grips the spindle by three prongs that fit into
three similar cutouts in the spindle.
The stylus comes off by pulling straight off.
Two fingers on one hand grab the cartridge while holding the tonearm with
two fingers on the other hand to take up the force of the pull and then separate them.
