Latest post 08-31-2009 10:18 AM by tomap. 2 replies.
Page 1 of 1 (3 items)
  • 08-31-2009 8:00 AM
    • tomap
    • Not Ranked
    • Joined on 11-08-2007
    • Oslo
    • Posts 11
    Beo5 and red color.
    I just bought a second hand Beo5, and I look forward to configure it.
    I was a little surprised about the red color it seems to be more like orange.
    Is this possible to change and is it common?
  • 08-31-2009 10:07 AM In reply to
    Re: Beo5 and red color.
    When you say RED colour, I assume you mean colour settings of the text ?
    The colours are RGB (0 - 255) and so any colour really can be defined.
    If you are saying that you have set the colour to stTextColor="255:0:0" and it shows up orange, then there is a fault.
    Regards Keith....
  • 08-31-2009 10:18 AM In reply to
    • tomap
    • Not Ranked
    • Oslo
    • Posts 11
    Thanks,
    Yes I mean when you use the 255,0,0,. The same is when I go to the service menue and do a colour check, the complete red is close to oranje.
