Hi there
Thank you for this suggestion, I have already tried some detergent and a (soft) brush, but was wary of damaging the textured surface of the panels. It is safe to use wire wool when cleaning these parts? The panels are off a 700 series, not the later 707 with the Nextel finish (which I have, fortunately in a cleaner condition on a 707 in lovely 70s brown  ).
