Hi all
I'm sure this has been answered, but I've done a search and only found answers relating to a 1000 remote.
Basically, I have just bought an Overture which came with a Beo4 remote and a Beolink active. Try as I may I can't get the remote to work the Overture, and I'm wondering whether it needs to be set up or paired in some way? The post I found for the 1000 remote suggested it was set up for Opt 0, not Opt 1 - could this be it, and if so, how on earth do you change this on the Beo4 remote?!
Kind regards
Pete
