Latest post 07-25-2009 3:23 AM by joeyboygolf. 6 replies.
Page 1 of 1 (7 items)
  • 07-23-2009 11:36 PM
    • Dave
    • Top 50 Contributor
    • Joined on 04-17-2007
    • Brisbane, Australia
    • Posts 2,328
    Wobbly / Shaky picture on BC1 when using STB
    Hi, i'm wondering if someone could shed some light on this issue i have, i've tried two strong set top boxes with my BC1 recently and it is connected via a 10 metre scart lead (as it is on a high pole stand). I have noticed that the picture is slightly wobbly (like little water ripples). Is this normal? It does not do this when the DVD is on, and i don't remember the picture always doing this...?
  • 07-24-2009 4:35 AM In reply to
    Re: Wobbly / Shaky picture on BC1 when using STB
    The first thing I would try is a short scart in case the problem is interference.
    Regards Graham
  • 07-24-2009 10:50 AM In reply to
    • Dave
    • Posts 2,328
    Yes i do need to try that, if this is the case of interference how would i remedy this?
  • 07-24-2009 3:29 PM In reply to
    Hacksaw!!!Big Smile
    Regards Graham
  • 07-24-2009 4:22 PM In reply to
    Look at the cable run and get a better insulated Scart - I dare say Steve at Sounds Heavenly can help.
  • 07-24-2009 11:33 PM In reply to
    • Dave
    • Posts 2,328
     ah, after playing around with it for half an hour i realised that it's to do with the mode the television is in! When i assign V.TAPE as a V.TAPE connected the picture is clear and perfect. When i assign V.TAPE as a decoder connected it is grainy and wobbly. It must be to do with CVBS vs RGB!
  • 07-25-2009 3:23 AM In reply to
    I have a BV1 and the AV socket is configured as VTAPE to make the Sky Digital box work. Although configured as DECODER it doesn't work at all!
    Regards Graham
