Latest post 07-28-2009 2:49 AM by Julien Chick. 5 replies.
Page 1 of 1 (6 items)
  • 11-28-2008 5:23 AM
    BM6000 Volume Dial Light
    On my BM6000 (80's one) the volume control is a lot dimmer at one end, the full volume end. I see on the circuit diagram in the service manual there are two lamps for this, one at each end I presume. Therefore I reckon that there is a blown bulb on mine. Does any one have any experiance of changing these or know if it is a tricky job. If its too hard I wont bother as I can live with it. If its not too had I will give it a go. Also what type of bulb is it?
    Cheers
  • 11-28-2008 11:40 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: BM6000 Volume Dial Light
    The lamp is soldered in.
  • 11-28-2008 4:23 PM In reply to
    • geearr
    • Top 200 Contributor
    • Joined on 03-27-2008
    • Gold Coast, Australia
    • Posts 301
    • Gold Member
    Hi
    Bulb type is 6v, 80mA, half watt - still readily available I think.  I replaced one in the BM6000 very recently and this was one of the easier bulb replacement jobs that I have had to do.  If you can solder, give it a go.  If you need any more assistance just ask.
    Regards
    Geoff
  • 11-28-2008 8:05 PM In reply to
    • geearr
    • Posts 301
    • Gold Member
    Hi
    Correction needed here, I guess I was thinking about the tuning globes.  The globes in the volume indication setup are the larger item, 6v and 1 watt.  The smaller globe was for the tuning indicator.  I have just had a quick look at the BM6000 internals to refresh my memory and yes, it is fairly easy to replace these as follows:
    Slide out the centre strip under the display
    Remove the glass panel by lifting at the front and pulling forward
    Split the casing by undoing two screws and opening up
    Release the six or seven black clips on the back of the PCB that hold the facia panel
    Ease out the volume slider and take the facia panel off.
    This gives good access to both globes
    Have fun
    Regards
    Geoff
  • 12-02-2008 3:33 AM In reply to
    Many thanks to all. When I am feeling brave, I will give it a go!
  • 07-28-2009 2:49 AM In reply to
    Hey folks, i just completed this procedure using the instructions in this thread....worked a treat, and easier than I thought it would be.
    Thanks Geoff.
    Julien
