Hi Matt, with a scope (oscilloscope) and some tech tv knowledge you can do something but do you have these ?? :)
In any case: it's either the scan part (not caused by a defective tube, that doesn't give this result, nor by a defective Line transformer as there wouldn't be any HT and no picture at all) or it's in the video part which, if i'm not mistaken, does the curtain part.
The start would be checking the deflection signals present on the deflection coils, a likely cause if there's something wrong here is a broken cap.
