Latest post 07-27-2009 3:47 PM by striker27. 11 replies.
Page 1 of 1 (12 items)
  • 07-17-2009 6:28 PM
    Master Link Distribution Box???
    I have had the opportunity to see a Master Link Distribution Box on Ebay and I love the fact that you can use pre terminated cables which is exactly what I have and am hoping to do.   What I would like to know is where can I buy one of these fancy little black boxes!!!!
    Do I have to go into the used market to get one???  Are they voltage sensetive????
    THANX
  • 07-18-2009 2:35 AM In reply to
    Re: Master Link Distribution Box???
    There are several different types of Masterlink connector/distribution boxes available from many retailers.
    Below are three examples
    The are just junction/distribution boxes and have no seperate power.
    Regards Keith....
  • 07-18-2009 3:16 AM In reply to
    Where would one go about getting one such as that on the far right???  It appears that junction box would be able to use pre terminated cables??
  • 07-18-2009 8:22 AM In reply to
    These are made/distributed by Bosscom of Denmark and you can view their B&O products HERE
    You are correct the right hand ones are for pre-made cables.
    Unless you are a retailer you cannot normally purchase directly from Bosscom, but they do provide a facility to tell you where your nearest retailer is located.
    Regards Keith....
  • 07-18-2009 5:21 PM In reply to
    I think this is the one your after? I bought mine from lifestyle av on ebay. Ive seen these sell for £60 on ebay but i got mine for £20 if i remember correctly.
    Never Mind The Ball-Cocks www.markmossplumbing.co.uk
    A labourer uses his hands
    A tradesman uses his hands and his head
    A craftsman uses his hands, his head and his heart
  • 07-18-2009 5:42 PM In reply to
    • RobN
    • Not Ranked
    • Joined on 05-15-2007
    • London, UK
    • Posts 57
    • Gold Member
    The Bosscomm boxes are good and I've used a few on my network, but you can just as easily buy a terminal block/strip from Radio Spares or Maplin and splice MasterLink very successfully.
    I've done this to great success and actually think it gives a better long term connection than the push-fit wire sockets on some connectors.
    Just make sure you then put the connection block in a small earth screen box.
    Best
    Rob
    BV7-32, BL8000, BL2, BL6000, Humax, AppleTV3, MX4200, V8000, Humax, BS3200, BL6000, BL4000, BeoPort, MacMini+DACmagic
  • 07-18-2009 11:23 PM In reply to
    • Russ
    • Top 100 Contributor
    • Joined on 05-07-2007
    • Washington, DC USA
    • Posts 641
    Thank you Plumber.  We're all here because we love B&O, but we're all looking for low cost alternatives which put money in someone else's pocket?  The ML distribution box shown in Plumber's photo will allow you to use the pre-terminated cables you mentioned in a very simple manner, and if you need more that 6 connections they can be ganged together with no problem, and no need fro external powert.
    We kid because we love.
    Bang & Olufsen Tysons Galleria
    McLean, VA USA
  • 07-19-2009 4:51 AM In reply to
    That is exactly what I am looking for!!!  Hopefully I will be able to purchase one!!!  Just have to start looking for them on the auction site and through dealers.
    THANX
  • 07-27-2009 4:57 AM In reply to
    Other than LifeStyle AV, Bosscom have informed me that their full range of B&O related products may be purchased from www.linksupply.dk
    Regards Keith....
  • 07-27-2009 12:04 PM In reply to
    I may be thinking a bit outside the box here but how about trying a Bang & Olufsen dealer, you never know, they may actually be able to get Bang & Olufsen parts???!!!
  • 07-27-2009 3:31 PM In reply to
    Absolutely right Gringomatt but i was never able to find a model number to safely order from my dealer thus buying from ebay knowing i was getting exactly what i wanted.
    If a dealer can supply these i think they should be on display in store or on their website.
  • 07-27-2009 3:47 PM In reply to
    Thanks for the info...
    I would like to say I would love to buy from my dealer.  The only problme I have is being located in North America, Canada precisely I am over 4 hours from my nearest dealer in my own country and 5 hours from the nearest in the Untied States.  Buying B&O is not an easy thing for me to do. Nor is getting to my nearest dealer.  Something that I have been lucky to manage two times this year.  The dealers or I should say the three that I have been to are incredible and wonderful to deal with.  They would prefer to sell a whole house system something that I would not mind doing as well as individual components I have purchased.  They are just 4 hours at the least away from me.  Once the store in Detroit closed it doors 2 or so years ago it has left me without an avenue to even discuss B&O until I found this forum.
    The North American forum is not all that ctive compared to this one so I prefer to post here.  It really does get you a quick answer to almost any question.
    THANKS guys for your patience with me!!!
