Latest post 07-27-2009 4:21 PM by Peter. 1 replies.
Page 1 of 1 (2 items)
  • 07-27-2009 3:33 PM
    Beomaster 900 advice please
    Hi just been given a Beomaster 900 and want to know wgat it is like sound wise and will it run ok with my Goldring G101 turntable, also what tape deck would be suitable?
    MTA
    Colin
  • 07-27-2009 4:21 PM In reply to
    Re: Beomaster 900 advice please
    This is the first all transistor set from B&O so you need to allow certain foibles due to age. Warm and easy sound - you don't say if yours is the K or M model (the K has built in speakers). The phono input is designed either for a crystal pick up or line level so you need a RIAA if you don't already have one. Any DIN rated tape recorder will do - a B&O reel to reel machine would be a good match.
