Latest post 07-11-2009 8:23 AM by Razlaw. 1 replies.
Page 1 of 1 (2 items)
  • 07-11-2009 6:19 AM
    • Seanie_230
    • Top 75 Contributor
    • Joined on 04-20-2007
    • Milton Keynes, England
    • Posts 962
    • Gold Member
    Apple Remote PUC
    Hello Fellow Beoworlders
    I have apple tv and this works nice with my BV7 Mk3.
    I have the newest version of the PUC for apple remote and the up and down repeat functions works fine but there is a problem that the unit does not get turned off my the tv and you cannot bring up the menu that comes up by holding down Play/ Pause on the apple remote (genuis menu)
    Is it possible to report this to B&o and request they add soem more functions to the PUC???
    Beovision 7 MKIV (Blu Ray)
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Optoma HD65 Projector
    Lintronic TT455-RT-238
    Beovision 3 MKII
  • 07-11-2009 8:23 AM In reply to
    Re: Apple Remote PUC
    I have noticed the same problems. In fact what I notice is that when turning the BV7 off the IR emitter on the Apple TV flashes, the Apple TV turns off (the power light goes out) but the emitter flashes some more and it turns on again. Prior to having Apple remote in the PUC list I had used the learning function of the Apple TV to learn commands for another product. This worked fine although again I could not use the Genius function. It appeared to me that the issue is for the Genius function to work the button needs to remain pressed and send a constant signal. It did not appear to me while teaching the Apple TV the Beo 4 commands that the Beo 4 is capable of sending a constant signal. Pressing a button on the Beo 4 results in only one brief signal, regardless of how long the button is held down.
    Beosound 1, 5, 2000, and 3000
    Beotime, Beotalk, Beocoms
