1st March February 2012
Latest post 01-22-2010 1:25 PM by bayerische. 7 replies.
01-21-2010 9:12 PM
auclutch
- Joined on 06-02-2007
- Posts 66
beosound 9000 door not opening/closing
hi,
so our housekeeper/nanny decided to change a CD in the 9000 and instead of using the eject/load button manually opened the glass door about 1 inch and removed the disc. now the door only opens half way and won't shut all the way. is there a way to reset the position of the glass? i went over the service manual but couldn't find anything there. thanks in advance!
BS1 x 2, BS 3, BS4, BS2000 x 3, BS2300, BS4000, BS9000, BL4, BL 4000 x 2, BL8000 x 2, BL2500 x 2, BL2000, Beocom 2, Beocom 6000 x 4, Beocom 1401 x 4, Beocom 1600 x 2, Beocom 2500 x 4, Beotalk 1200, A9 Keyring, Beo4 x 8, Beotime, Bottle Opener
2011 Wish List: BL3500, BL6000, BL5, BL9, active link, BS5, Beo5
elephant
- Joined on 04-16-2007
- Melbourne, Australia
- Posts 2,215
Re: beosound 9000 door not opening/closing
auclutch: our housekeeper/nanny decided to change a CD
time to change the nanny
When my BeoSound 4 door gets stuck I power it off at the wall and apply gentle pressure to slide it into its home position and then power on the wall socket again.
Mind you that process is what is described in the installation manual since one has to fit the glass oneself.
First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
auclutch
- Posts 66
thanks, i'll give that a try when I get home. i am slightly worried that the glass might detach if I place too much pressure on it.
saf
- Joined on 04-17-2007
- Posts 458
auclutch: thanks, i'll give that a try when I get home. i am slightly worried that the glass might detach if I place too much pressure on it.
I wouldn't attempt to use pressure ... instead - only if you feel comfortable with that - put the BS9000 flat somewhere save (your bed eg) connect it to power and open the glass lid pressing the eject button, disconnect BS9000 from power, locate the tiny screws on the hinges and loosen them : Be very careful with the lid holding it all the time - when the screws are loosened the lid can be dettached completely hence the risk of dropping it!Try to reseat the glass to its correct max open position tightening the screws again. Power it up and see if this helped.
auclutch
- Posts 66
Thanks for your response saf. Actually, before I read it, I had tried something else that worked. I unplugged the BS9000 and then softly pulled the lid open to the max open position. there was a slight click (as if it had resocketed itself) and now everything works just fine!
THANKS a BUNCH.
joeyboygolf
- Ely, Cambridgeshire, UK
- Posts 3,252
The drive to the glass door is designed to be detachable so you can lift the glass in a so called emergency!
Not sure what sort of emergency would warrant that action?
Daniel
- Svinarp, Sweden
- Posts 1,284
joeyboygolf:
A fire that cause a power outage and you must save all your signed CDs with Spice Girls that now are stucked in the BS9000?
bayerische
- Joined on 12-11-2007
- Helsinki, Finland
- Posts 3,593
Daniel:
joeyboygolf:
The man has a point!
Good you got the problem sorted.
-Andreas
BLab5, BLab5000, BLab8000, BV10, BS9000, BS3, Beo5, Beo4, BLink1000, BLink5000, BLink7000, A2, A8, Form2
Page 1 of 1 (8 items)
