Here is the conclusion from the configuration guide which indicates that I was on the right track but the grey matter is not what it once was!
************************* VIDEO SYSTEM SETUP **************************
Beovision MX 7000 Beo4
Connection Video
Connect the aerial to the aerial input of the TV-set.
Selecting option on the TV-set
Option: OPTION 1 (Factory setting), with Beo4
Press: | Display:
STANDBY + LIST at the same time | OPTION?
GO | V.OPT
1 | Observe confirmation
| from BeoVision
When using the remote control mute function, sound is
restored by turning the volume up or down.
************************* AUDIO SYSTEM SETUP **************************
Beocenter 9000
Beovox passive
Connection Audio
Connect the Beovox to the SPEAKERS 1 socket on the audio
master using a loudspeaker cable.
Connect the aerial to the aerial input of the audio master.
Selecting option on the audio master
Option: OPTION 1.5
Press: STAND-BY SOUND 1 STORE
SOUND 5 STORE
If option programming is made using Beolink 1000 MK3/MK4 or MK5 press
LINK before the sequence SOUND x STORE
Press: | Display:
GO | V.OPT
LIST | A.OPT
| from AudioMaster
********************* AUDIO/VIDEO/LINK SYSTEM SETUP *******************
To obtain A/V intergration between these products the audio master
must be equipped with a Beolink software, part no. 8341052.
If the audio master is equipped with a Beolink software, it is
indicated by a sticker marked BEOLINK on the rear panel.
Connection
Connect the AUX socket of the audio master to the AUDIO AUX
LINK socket of the TV-set using a 7/7-pin DIN cable.
Note!
All Timer PLAY programming must be made on the radio.
Set Timer ON/OFF to ON on the products to be switched on via the
Timer programming.
********************* REMOTE CONTROL FOR MAIN ROOM ********************
The recommended remote control is Beo4
The following remote controls may also be used:
Beo5
Setup for Beo4 remote control:
Beo4's "LIST" must contain the following items in order to be able
to operate the Main Room products.
CLOCK
LARGE REVEAL INDEX UDDATE MIX SUBCODE STORE
V.SETUP (only with S/W 2.0 or higher in Beo4)
A.SETUP (only with S/W 2.0 or higher in Beo4)
AV (only with S/W 4.0 or higher in Beo4)
See Beo4's operation manual page 10/12 on REMOVE and ADD functions
from/to the List
Note!
Beo4 must be equipped with software (S/W) 2.0 or higher to operate:
Setup and tuning functions on the Videomaster.
The software version can be read on the Beo4 display by
pressing (STANDBY LIST) and then (MENU GO) at the same time.
Order No. 8001827
