I do have the the original remote Keith. I problem is I don't have the equipment or knowledge on how to create XML files!
I believe you need a device to capture the IR codes, but with the Macbook Pro I have there is no IR port. I don't have a palm pilot or anything else like that either.
Help!
32" RF VCR Avant, 2 x 28" VCR Avant, DVD1, Beocom 6000, Beo5, A9 Keyring!
