Latest post 06-21-2009 4:25 PM by vodomar. 3 replies.
Page 1 of 1 (4 items)
  • 06-13-2009 6:00 AM
    Beocord 3300
    I have recently acquired a Beocord 3300 and it worked fine. Today I inserted a cassette and pushed a play button but it would not move. Whatever button I press, nothing happens - the cassette is stuck in (the heads have locked into the cassette and will not retract) and I cannot get it out. All the ligjts are lit and everything seems to be OK. The tape deck is linked to a Beomaster 3300. What do I need to do?
    Filed under:
  • 06-13-2009 12:17 PM In reply to
    Re: Beocord 3300
    Turn off the power first and see if that helps. It sounds as if you have a belt problem - Martin can get you new ones.
  • 06-14-2009 1:57 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Beocord 3300
    Don't force the stuck tape out !
    The belts in your Beocord will have stretched or degenerated, that's normal with age.
    I can supply sets of drivebelts for Beocord 2000, 3300, 5000, 6000, 6002, 8000, 8002, 8004, 9000 and
    several others.
    If can include mounting instructions, they will also tell you how to remove the stuck tape without breaking anything.
    You have a PM (check your inbox at the top right corner).
  • 06-21-2009 4:25 PM In reply to
    Re: Beocord 3300
    Thanks! I did switch it off and on again and it relesed the cassette. Quite simple.
