Hi all:
Apologies for staring a new thread but I think this is the easiest way to get specific responses:
As some know I am building a media server. The board I am using is this one:
http://www.foxconnchannel.com/product/Motherboards/detail_spec.aspx?ID=en-us0000006
I haven't built a PC for ages however, I am fairly competent. I think I have a RAM or RAM configuration issue. Basically the board acepts DDR2 memory only accross 2 banks of 2 slots (four in total). I am running low on funds so only bought 1 strip of 512mb 533mhz RAM and it ithis type of RAM is supposedly compatible. Without RAM installed the machine spins up and then emits the expected beeps and goes no further (this is obviously supposed to happen). When I install the 1 strip I have the beeping stops yet nothing appears on screen and the fans spin only. I have a floppy connected for testing and this does not boot - so this is a RAM problem as far as I can tell.
I guess the problem is caused as a result of the RAM not being installed in pairs however, this is based on anecdote rather than fact. I also guess this is because the board is set to dual mode yet this seems to be determined by the bios as opposed to a jumper so I cannot change the settings because I cannot get into the bios (also there is no keyboard connected yet I doubt this is the problem.
The MB manual entry on RAM states:
This motherboard includes four 240-pin slots with 1.8 V for DDR2. These slots
support 256 Mb, 512 Mb and 1 Gb DDR2 technologies for x8 and x16 devices, and
support maximum memory bandwidth of 8.5GB/s using DDR2 533 memory, 10.
7GB/s using DDR2 667 in Dual-Channel interleaved mode, You must install at
least one memory bank to ensure normal operation."
Yet this sheds no further light on the issue. Can someone please tell me if I have to buy another strip or indeed what else I might be overlooking.
Graham
