Hi again.
A slightly different issue. I have hard a couple of times that BV 7-40s still at the dealers have had some kind of panel error. Panel needs to be switched for another or corrected somehow. I am about to buy a MK III from my local dealership, and would like to know if any of you know of such "common" errors?
Is there anything in particular I should be on the lookout for? Could I be as lucky as to have it replaced for a 100 Hz panel as a sparepart....?
Thanks!
BV 7-55, BL 7-4, BL 9's, BL 4's, BL 3's, BC 2300, Beo5, Beo4
