Latest post 06-10-2009 2:12 PM by Ehlerz. 4 replies.
Page 1 of 1 (5 items)
  • 06-07-2009 2:54 PM
    Appletv sound in linkrooms
    Hi all
    I have an appletv hooked up to my 7-32 with DVI and analoge soundcabels. Why cant i listen to sound from the appletv on my two linktv´s? It is possible on my BL3500?
    TIA
    Ehlerz
    BV7-40 MK IV, BL5´s, BL3´s, BL 3500, BL7-4, BS3000, BC 6-23, BV 1, BS3.
  • 06-07-2009 4:01 PM In reply to
    • DocD
    • Not Ranked
    • Joined on 06-07-2009
    • Posts 1
    Re: Appletv sound in linkrooms
    Hi
    I used to have the same problem (Mac Mini connected to BV7, connected with DVI and minijack for sound, assigned to PC button) - but I could get the sound through to linkroom by turning linkroom speaker on manually/direct (linkroom speaker stand-by - mainroom playing), and not by remote control in link room. Sorry if that was a bit cryptic... However:
    I changed the connection so the Mac Mini was still connected with DVI - but sound was connected via SCART - and assigned it to V.MEM, which work as a charm from linkroom as well as main room.
    Hopefully that could work for you?
    Best Regards /DocD
  • 06-09-2009 3:49 PM In reply to
    Problem Solved.... Issue was that the linkroom tv´s thinks they recieve a picture and therefore uses the coaxial cable for picture and sound (ignoring the masterlink). AV DTV did the work....
    Thanks anyway DocD, maybe you can use this solution as well.
  • 06-10-2009 7:29 AM In reply to
    • Dave
    • Top 50 Contributor
    • Joined on 04-17-2007
    • Brisbane, Australia
    • Posts 2,328
    Ehlerz:
    I didn't know that was how B&O link worked... sound is via masterlink, only picture is via the coax... isn't that right?
  • 06-10-2009 2:12 PM In reply to
    I was told otherwise... You should be able to watch a DVD on your linkroom tv without masterlink ( i think??) But i am not sure, however it worked for me so who cares how it works :-)
