I had to recently replace my very old MX5000 TV with an interim LG 42PG20R Plasma TV.
I was using a Beolink converter to connect the MX5000 to my Overture (to create a mock surround sound).
The overture is connected to a beolink converter (using the master link) this then outputs from the audio aux link into the MX5000 TV.
So, my question to you is there anyway I can connect from the Beolink converter to the LG Plasma TV?
I suspect that if this is not possible I will have to buy more speakers!!!!
The ports on the LG are as follows.
| Jack Pack |
| Side : AV In (1) |
| Side : S-Video In (1) |
| Rear : RF In (1) |
| Rear : AV In (1) |
| Rear : AV Out (1) |
| Rear : Component In (2) |
| Rear : HDMI In (2) |
| Rear : RGB In (1) |
| Rear : PC Audio In (1) |
| Rear : RS-232C (1) |
| Rear : Variable Audio Out (1) |
Happy to provide as much info as possible to solve this - thanks in advance.
Pete
