Hi
Quick query, dose anyone know if it would be possible, to use the master link converter to add an additional analog line in to a BS 9000.
My Plan was to plug my non B&O lcd into the audio aux plug on the ml converter, then connect that via ML to the 9000 to send the tv's sound through the speakers attached to the 9000
Unable to use the aux plug on the 9000 as i already have a sonos zone plugged in.
Cheers
Tom
