Second posting on my recently acquired Beocenter 1.
TV was previously part of a linked system with separate audio and Beo 6 LCD TV. The previous owner unfortunately doesn't know enough about how it was all set up (before he removed it all from his apartment and put it into storage.) There is no FM radio on the BC1 but the menus show it was linked to an external radio source. Link option is set to Option 1. According to the manual this was for TV and audio in the same room. (Option 2 is TV and audio in separate rooms, and is the default option when new), option 5 is identical to option 1, option 6- the tv is the only product in the link room. There is no mention of options 3 or 4. I assume I can reset to option 2 by resetting the TV to its defaults (which will unscramble the STB and other connections as well) or I can choose an option through the Beo4 (??)
Is Option 2 also the correct option for when the BC1 is being used as a stand alone unit and will this reactivate the radio? I guess I am looking for some sort of reassurance from those of you who are more expert in these things before I blunder into the service menu options and maybe cause additional problems for myself!
The service counters show that the BC1 radio has never been used (TV has only 30 days video/ dvd use from new.) (Radio days 0, Radio on (T*10) 2). STB module is present and the ML module (TV was linked, ML ref on rear label and ML socket present and exposed.)
Vikinguk
I used to be indecisive, now I'm not so sure. [W C Fields]
